keyless entry ???
I am the proud new owner of a 97 D1. Its has a couple of little quirks but the one that I have a question about is the keyless entry. The FOB doesnt work the keyless entry to well. It works randomly. I was told by the PO that the locking mechanismsm need to be greased. Is that the problem or is there something else I should be looking for?
I will second this and as a professional I have told this to MANY customers, it uses your body as a transmitter.
I do this with our Grand Caravan and my G/F looks at me like Im on crack, but it works. I will do the batteries first since that is the cheapests. Would all the acuators go at the same time? Or when one goes none of them work?
If none of them seem to be working I would try manually pushing the inside lock switch on the drivers door (and passenger front door) up and down, if it goes up and down freely and none of the other doors lock or unlock then your problem isn't the actuators but something in the central locking. If one of the actuators are bad they usually seize up causing the manual locking not to work (the lock will feel stuck).
on a side note if it helps:
These trucks use a 1 wire locking system, the wire is yellow/pink in the drivers kick panel (behind and under the hood release) the way the 1 wire locks work in this system is the wire will contain a signal if the wire is cut (or a pulse switch is put inline and then opened) the doors will lock, if a pulse to ground is applied (or a pulse switch to ground is closed) the doors will unlock.
