Keyless entry issues
Light comes on when button is pressed on the FOB
Key works to lock and unlock all doors when inserted
No horn or beeps when key is used to toggle door locks
Keyless locking/unlocking does not work at all
Does the receiver control horn/alarm beeps?
All fuses are good-- even replaced just to be sure
2000 D2 SE7
2000 D2 SE7
Try the fob buttons while sitting in the back seat with the key near the roof. My receiver went out a few years ago and over a few months, the range would steadily decrease until I had to be right on the vehicle before it would pick up the signal. Got a scrapyard unit for cheap and it works fine now. My range has never been great though, 30-40 ft max.
Thanks! I will try that. Would the alarm beeps sound if the key is used in the door to lock the vehicle? I get no sounds.
It could be from another truck(physical key put into a shell from another truck), and/or never programmed.
And, all U.S D2's use a 315mhz key, not the 433mhz. You will need a Nanocom to program them too.
Your body acts like a bigger antenna to send/receive the signal.
JUKE179r (11-28-2019)
