Keyless entry receiver module location?
Old Jun 19, 2014 | 06:27 AM
PaulMc's Avatar
Originally Posted by PaulMc
They're $hittin' you
Thinking about this, I may have been a little harsh there
For the money that they've quoted, and the requirement to re-programme the keys - I think that they've quoted you for replacing the BCU, rather than the alarm receiver.
Old Jun 19, 2014 | 08:21 AM
jafir's Avatar
I'll mention that on my MY2003, that the remote stopped working, and I was unable to re-program it with my hawkeye, even though I had the codes. I figured that I needed an new receiver, and left it alone. Before I got around to buying a replacement part, I was using the hawkeye (or the nanocom?) to play with some settings on the BCU to see what they did. After I was done, the remote started working again. I think maybe the BCU was just locked up or something and needed a reboot.
Old Jun 19, 2014 | 09:26 AM
OCMike's Avatar
Well, now I don't know if I should replace the keyless module just yet. It could be that, or the BCU, or could it be the interior fuse block?
Here's what I know so far:
* The first place I went to said they would reprogram my keys for free. Hooked up their Autel, and when he got to the screen just before entering in the key code, the buttons on the Autel screen would flash on and off. He had to time it just right to hit the correct button to get to the next screen to enter the codes. Maybe one of the units has a short?
* I also heard the horn go of a few times when they tried something different. I think they were turning the key a certain amount of times in the door lock or ignition. I think I read something about that somewhere.
* The central lock button does work. Everything else in the truck works, also. I show no codes on my cheapo scanner.
Also, when I said $120 to program the keys, I should have said $60 for each key.
Old Jun 19, 2014 | 10:06 AM
OCMike's Avatar
I'm pretty sure he said it was the keyless entry module, when I called back the next day to go over his estimate. I asked him if it was the alarm/keyless entry module, and he said yes.
Old Jun 19, 2014 | 11:40 AM
jafir's Avatar
the problem is there isn't just one module that does all functions of the alarm/keyless. So he might be trying to sell you a BCU or he might be trying to sell you a receiver.
Old Jun 19, 2014 | 05:02 PM
abran's Avatar
I called Autologic tech support and they confirmed that the receiver needs no programming, plug and play.
Mecevans
Aug 9, 2015 02:30 PM
Frank4
Mar 21, 2014 05:21 AM
FORDSTANGER
Aug 9, 2005 01:00 PM
pvalianatos
Mar 12, 2005 05:20 PM
