klunking ..... again
Old Jul 3, 2007 | 09:09 PM
inabinn's Avatar
Default klunking ..... again
ok so i've been driving my new disco more and more now but i still cant get over the kulnking comming from the transfer case. it isnt all that bad but it gets annoying after a while. i know that this vehicle is know for this sound but is there a specific speed that it should be felt at ? the worst felt klunks are right around 35mph but at lower and higher speeds it isnt as noticable. i've been told on here also that i need to replace the u-joints and grease them and some other stuff but i have no idea how much this would cost nor do i have the confidence to do it myself becuase i never really worked on cars before. so i guess what im asking is how much can i expect to pay to get this fixed and could a novice mechanic do it with proper instructions( the most i've ever done on my truck is install an intake and exhaust)
Old Jul 3, 2007 | 09:27 PM
okdiscoguy's Avatar
Default RE: klunking ..... again
Not sure what year you have, but if you have a diff lock, you can un-bolt the front and drive it with the diff locked. You can take it by a driveline specialist. Call them first and get a quote. It migh only be $50 difference if you take it off. Not worth it to me....
Good Luck!
Old Jul 4, 2007 | 10:22 AM
What you are experiencing is not normal, send me your tele number and a good time for me to call you and I'll try and help you.
Mike
mikeljacobs@comcast.net
garover
Feb 13, 2019 07:18 PM
abran
Jun 30, 2014 12:43 PM
Sean 1313
Oct 1, 2005 03:19 PM
kirk4
May 16, 2005 11:39 PM
