Knock Sensor Bank 2 Broken Wires at the Plug
Old Feb 3, 2020 | 08:35 PM
disconic's Avatar
Default Knock Sensor Bank 2 Broken Wires at the Plug
Howdy Folks. I had a knock sensor bank 2 code on my scanner. Upon investigation it appears the old brittle wires had completely broken off from the end of the plug itself. I scoured the internet for a replacement with no luck. There is no way to splice this together because I don't have anything to work with on the plug end. Splicing seems like a bad idea anyway. Does anyone have any ideas on how to go about this? It almost looks as if you can remove the pins with some sore of tool. I suppose it probably wouldn't hurt to replace the entire wiring harness, being a 2003, but I would like to avoid that if possible. Thanks.
Old Feb 3, 2020 | 09:04 PM
Boostle's Avatar
You should definitely be able to get a de-pinning tool (probably off amazon) to get the pins out.
You're in a much better situation than I. My wire is broken and soldering it back together did not work very well since it has a shielding cover over it that I didn't put back together too well. I'll have to pull the AC compressor and bracket behind it to try to repair it again.
Old Feb 4, 2020 | 04:23 PM
miron's Avatar
You can get a pigtail plug for practically any sensor on the engine car on amazon. You might have to look for old BMW as well (they use the same engine management/sensors). Also if one is broken, then more will go soon (like mine did: injectors, evap solenoid, oil presusre) get a used harness.
Old Feb 4, 2020 | 07:25 PM
disconic's Avatar
I'm having a hell of a time trying to find one. This is what I'm looking for but I'm running circles trying to find it. I think you're right, it may be time to replace the entire harness. Is it possible to find a new one?
Old Feb 4, 2020 | 07:45 PM
miron's Avatar
Hi,
I'd try going to a pull apart and snipping off one myself or emailing one of the eBay Landrover used parts people the will find one for sure. If you would rather go with new, search Amazon not necessarily for this exact fit i.e
Amazon Amazon
looks like it might fit. LR is a Bosh system, so they use exact same plugs on BMW, vw, Audi, and couple other German brands and even Japanese.
lastly you can purchase a "variety" pigtail pack and hope one of them will fit with some persuasion.
jfall
Jul 16, 2020 08:31 PM
zuke
Jul 21, 2018 12:13 PM
BOZA
May 8, 2017 08:26 AM
mollusc
Dec 11, 2016 09:52 AM
SailorTom
Mar 11, 2015 09:58 AM
