Knock sensor connector repair
Old Jan 10, 2017 | 09:16 PM
Luckyjayb's Avatar
Default Knock sensor connector repair
Well while I was putting the heat shields back on, I noticed the connectors for the knock sensors were shot. The passenger side has fraying on both wires. The drivers side doesn't show any fraying I can see but I'm sure if I replace one, might as well do both. Anybody know where to get the connectors and leads? The frayed wire is at the connector so I'll need a new connector on the passenger side for sure.
Thanks
jason
Old Jan 11, 2017 | 06:43 PM
Luckyjayb's Avatar
Anybody got any ideas?
Old Jan 11, 2017 | 07:17 PM
LR03NJ's Avatar
Its almost like a smaller coaxial cable then split to the sensors below left and right. I think it will throw p0327 but wont trigger the ses light. If you need to get the similar cable, you can go to markertek, its a shielded thin BNC cable. But a regular stranded wire will do like what I did.
Old Jan 11, 2017 | 07:25 PM
Luckyjayb's Avatar
Ok BC I saw it was shielded cable and it didn't throw codes before I did the head job but when I was wrapping new loom covers on it, I noticed it and trying to be proactive. My only concern is that it's right at the connector so I'll need to get a new connector. Any ideas where to get them from
Old Jan 11, 2017 | 07:56 PM
LR03NJ's Avatar
Try this
OEM & Aftermarket Connectors - Wiring Products
Old Jan 11, 2017 | 08:12 PM
Luckyjayb's Avatar
Originally Posted by LR03NJ
Couldnt see anything similar. I might have to wait till the pull a part gets one in and make some cuts
Old Jan 11, 2017 | 08:44 PM
LR03NJ's Avatar
This is the knock sensor. Just the other female connector you need, right?
Old Jan 11, 2017 | 08:49 PM
Luckyjayb's Avatar
Yea that's right. Looks like a 2 wire hook up
Old Jan 12, 2017 | 01:56 AM
number9's Avatar
Many connectors have removable pins/sockets. If yours in good shape may be able to replace the sockets/terminals?
Old Jan 12, 2017 | 09:24 AM
abran's Avatar
I just did this recently. Since it's right at the conne tir you can cut the connectors off a junk loom up to the splice(the 2 wires go to one in a bizarre splice) and solder/heat shrink both wires.
or email Paul in the U.K., he has what you need.
lr_connectors@btinternet.com
