Knock Sensor & Starter Heat Shields
Old May 20, 2023 | 05:00 PM
WildPackofFamilyDogs's Avatar
Default Knock Sensor & Starter Heat Shields
Are they absolutely relevant?
Do you folks put them back on after you take them off to do work?
Old May 20, 2023 | 06:43 PM
zski128's Avatar
The starter one yes if you don’t want it to fail prematurely due to heat. The one on the opposite side of the engine is mailing to pretect the motor mount. Same thing, heat will destroy it overtime.
Old May 20, 2023 | 08:36 PM
Discorama's Avatar
The exhaust manifold radiates a lot of heat. After 20 years the wiring loom is mostly toast. It crumbles if you squeeze it with your fingers. I just replaced it on most parts of the wiring harness, since the engine is out at the moment. Yes, the heat shields are absolutely necessary and there are areas which need more heat shield.
Old May 21, 2023 | 08:28 AM
Xanthro's Avatar
If anything, more heat shields are needed. You may not notice an issue immediately if you don't replace a heat shield, but you will over time.
Since these vehicles are all near 20+ years old, the effects of heat over time are being scene. Don't remove any of the installed heat shields.
Old May 21, 2023 | 03:17 PM
Extinct's Avatar
Yep, while you have your heads and exhaust manifolds off go ahead and remove the CPS cover and wrap that in aluminum foil also.
Edge77
Nov 5, 2021 10:19 PM
Toran
Jul 26, 2020 03:32 PM
old gold
Dec 19, 2015 07:23 PM
Mark G
Sep 19, 2015 10:40 PM
HammerFit
Aug 2, 2014 08:39 AM
