Knock sensors
Knock sensors
Can my knock sensors be failing, and not give me a code for it? I get 7-13 mpg and a check engine flashing at random throttle positions including when I release the throttle. No stumbling, just no power. My code is a cyl #6 misfire.
03' disco 148k miles. New MAF, plugs, plug wires, o2 sensors, coils crank position sensor.
could a knock sensor be going and not throwing a code? anything is possible.
7mpg seems more like a bad O2 sensor than a knock sensor. A knock sensor is going to effect your timing.
I would go to whatever autoparts store you deal with and have them check for present code numbers, and then list them here.
