Knocking sound/Steering
Old Sep 19, 2008 | 09:27 AM
treho54's Avatar
Default Knocking sound/Steering
I have a 2003 Discovery SE and the other day i heard a knocking sound coming from the front passengers side wheel area. i stopped the LR and when i bent down to see if anything was hitting while my brother was turning the wheel back and forth, i heard a something that sounded like air being released. It wasn't from the tire, and the sound isnt constant. It almost sounds like how a piston would sound with the release of air and then knocking. Also i was in a accident and the idiots at the body shop fixed the exterior of the LR, but when i got it back, the steering is off. It feels like the steering column is bent a bit, and is not smooth, and you can feel a bump in the steering. I am not sure, but because the car was in an accident on the right side, could the impact have pushed something into the steering column bending it a slight, and if so, how do you fix questions (A), and (B).
All info, pics or comments would be greatly appreciated.
Old Sep 19, 2008 | 10:09 AM
Default RE: Knocking sound/Steering
Take it back and make them fix it right. Any number of things could be wrong. Does your truck have ACE?The steering box could have been messed up.
Old Sep 19, 2008 | 11:05 AM
treho54's Avatar
not sure what ACE is.
Old Sep 19, 2008 | 11:29 AM
Active Cornering Enhancment.
Open the hood and look on the power steering resevoir, if it has 2 caps then you have it. One of the caps will say ACE right on it.
mowensmd
Aug 21, 2024 11:07 AM
ViennaDisco
Aug 6, 2010 09:22 PM
Rover Chris
Aug 19, 2009 05:28 PM
larryrover
Mar 1, 2009 03:48 PM
MichiganJim
Nov 30, 2007 07:42 PM
