Lack of differential lock on 2000 disco
Old Oct 23, 2015 | 01:13 PM
Roto's Avatar
Default Lack of differential lock on 2000 disco
I needed to lock the differential today, but this is what I found. Any ideas on why I'm looking at what I'm looking at? Is this a 2003 case by some chance?
Original issue was U-joints on front shaft shot, replaced them, but now I have a very high frequency vibration from about 15mph. The drive shaft pieces orientation was marked and kept in reassembly.
Am I looking at having to replace the t-case to get diff lock back so I could drive one rear shaft if I had to?
Old Oct 23, 2015 | 01:56 PM
Lowest Bidder's Avatar
Yep! No diff lock there.
You could replace the whole transfer case, or just the front output housing from a suitable donor truck. Talk to Paul Grant, he sold me one a coupla years ago.
Old Oct 23, 2015 | 03:23 PM
mln01's Avatar
That's a bummer. Looks like the t-case was replaced with one from a mid-'01 to an '03.
Old Oct 23, 2015 | 04:34 PM
Roto's Avatar
Major bummer. I have to drive a few hundred miles on a driveshaft that is vibrating my spine out of me on NEW U-joints.
Old Oct 23, 2015 | 06:10 PM
Dave03S's Avatar
Did you rebalance the shaft? You don't mention if you've ruled that out.
Old Oct 23, 2015 | 09:04 PM
Roto's Avatar
Nope, I've never had to do that before when the relationship of all the parts was kept proper. I will be taking the shaft to a driveshaft shop next week to get the balance checked out.
Old Oct 23, 2015 | 09:43 PM
Dave03S's Avatar
OK so you replaced the U-joints yourself then... On the original shaft? You don't mention if you also replaced the center ball...
Often sudden symptoms are related to recent work.
TripleThreat
Jan 2, 2012 08:38 PM
smcevoy
Feb 20, 2008 02:37 PM
audiurq
Jul 1, 2007 11:52 PM
skrams
Feb 16, 2007 03:25 PM
RoverLife
Feb 1, 2007 11:16 AM
