Lamda Sensors Failure
Old Jun 17, 2018 | 02:07 AM
OffroadFrance's Avatar
Default Lamda Sensors Failure
Most Lambda Sensors can be carefully cleaned which saves replacement at huge cost. It often happens as the result of cheap or contaminated petrol and thereby 'throws' up DTC's indicating Lambda sensor failure. Some 'fuel additives' might improve ignition but there are some which cause Lanbda sensor problems and DTC's. Before replacing try cleaning them, nothing to lose.
Old Jun 17, 2018 | 12:01 PM
Externet's Avatar
How does cleaning work? Rinsing them in some specialized fluid ?
What is the effect of green, orange,... coolant chemicals to the sensors (from head gasket leaks) ?
Muggs
Feb 1, 2017 11:16 AM
philwarner
Jun 17, 2015 10:27 AM
dusty1
Feb 19, 2015 06:39 PM
Nay_Sayer
Feb 27, 2014 11:41 AM
Chris-bob
Aug 11, 2011 01:17 AM
