Land Rover D2 gear change problems
Old Mar 9, 2018 | 10:22 PM
Rozlyn's Avatar
Default Land Rover D2 gear change problems
hi all I have a 2001 disco 2 I have had the front drive shaft (front prop shaft) replaced about 8 months ago due to it snapped and also the transmission was done at the same time. Since then iv had no problems with her until today coming up the blue mountains I had stopped at a red light and when she was changing between 1st and 2nd (auto) there was some shudder or shaking but not bad but it doesn’t do it all the time last time this happened it was really bad shaking and in the long run the drive shaft let go and F***ed every think in its path I’m concerned the drive shaft might be on the way out again but want to see if anyone else has had this problem and what else it could be other then the front drive shaft
Old Mar 10, 2018 | 06:33 AM
The Deputy's Avatar
Was the trans a rebuild or used? Have you checked your trans fluid lately? Is the new driveshaft a serviceable model, that needs greased? If it'd s a serviceable driveshaft, should be greased every three thousand miles, or more, depending on use.
Brian.
Old Mar 10, 2018 | 07:34 PM
Rozlyn's Avatar
Trans was a low kms used one, fluid is fine and yes iv greased the driveshaft the other week
Brian.
Old Mar 10, 2018 | 07:50 PM
Best4x4's Avatar
Sounds more like driveline slack or TC issue.. I'd check your Transfer Case fluid. If the TC is acting up it'll cause all sorts of symptoms that could mislead you into thinking it's the transmission.
Old Mar 11, 2018 | 06:53 PM
OffroadFrance's Avatar
It does sound like the auto trans has burned out clutches IMO. Check out your ATF for colour and smell. If it's dark brown and smells like burned toffee it is most likely the clutches. With the autobox out it's easy to replace them.
The only Blue Mountains I know, having been there, is those near Sydney in Aus.
cycomer
Aug 21, 2016 06:43 PM
collin Barrows
Aug 28, 2011 07:13 AM
treant985
Dec 27, 2010 02:51 PM
sijan
Dec 9, 2008 05:32 PM
