Land Rover Damage
Old Sep 18, 2012 | 10:39 PM
suzukisam967m's Avatar
Originally Posted by Spike555
That is called a "alligator", it is the re-tread off of a semi truck tire.
It happens when the tire overheats from being overloaded or under inflated.
They can total a car if they hit it just right.
I know... I just figured if I said I hit an "alligator" people would think I had a big toothy critter stuck in the front of my truck
Old Sep 18, 2012 | 11:31 PM
4x4ron's Avatar
RL Parts has a rear quarter for $295.00, i guess it would still need to be painted.
Old Sep 19, 2012 | 06:12 AM
ebg18t's Avatar
Glad you are ok.
Old Sep 19, 2012 | 09:05 AM
04duxlr's Avatar
You could go the new quarter panel route, or you could straighten it out as best you can and bondo it smooth and paintit, or you can cut off the damaged area and graft on a section from a used quarter with rivets and structural epoxy followed with a skim coat of bondo. I think I'd go the straighten route, along with trimming the damage off the bottom coupled with a nice aftermarket bumper that wraps around to the wheel opening. Another trick you can use is to cover the area you can't get perfect with a texture spray like they use along rocker panels to protect against rock chips and then paint it. It's a truck, after all. A little creative taping and painting on both sides might make it look like it belongs there.
Old Sep 19, 2012 | 09:42 AM
4x4ron's Avatar
After looking at the panel there is more than just bolt on a new one.
This thing is aluminum and there are lots of spot welds that hold it together. I am meeting the claim adjuster this morning and once I find out what they think it's worth I will probably try to fix it myself with some creative repairs.
Definitely need a new set of tires that's first priority.
Thanks,
Ron
Old Sep 19, 2012 | 10:36 AM
jafir's Avatar
The spot welds go to the corner piece. You unbolt that with it, as one piece.
Old Sep 19, 2012 | 05:11 PM
Antmen's Avatar
Nothing to offer here other than 'glad you and everyone around are ok.
Old Sep 23, 2012 | 05:15 PM
jafir's Avatar
If it was a D1 they would total it. A lot of people will be wary of the aluminum. RAVE says hours rated for left side panel replacement is 13.4 hours. See shop manual under "Panel Repairs".
I was wondering why this should take so long for a bolt on operation, then I noticed they are including time for paint. They show 7.4 hours to replace the hood. I'm assuming the time would be greatly reduced for a used panel of the correct color, if it required no painting.
Old Sep 23, 2012 | 07:48 PM
Racer X's Avatar
Dude, it's a bolt on part, albeit a large one.
Old Sep 24, 2012 | 12:28 AM
00&04 Disco's Avatar
Ron,
I have a 2001 black DII with good paint that i use as a donor vehicle. Wish you were closer I could make you a good deal.
