Land rover disco II misfire
The plugs have been replaced in the last 2 weeks, they were not gapped. it threw a code for a misfire on the cylinders listed above. dont knwo the exact code numbers. truck hasd 105K on the odometer. alwasy ran 87 on it for lat 5 years..think it might be coil due to all of the cylinder misfireing on those specifinc cylinders. are they all on the same coil?
on
If you want help, you really need to answer the question replyed back to you so we know what you are dealing with.
What brand of plugs and wires and what year is it??
For sure you have carboned up your valves, burning cheap gas, hopefully you haven't damaged the valve stem seals.
marrtial
02-09-2013 08:17 AM
