Landy Heats UP like Hell
Old Apr 7, 2008 | 07:03 AM
ather90's Avatar
5th Gear
Default Landy Heats UP like Hell
Heya guyz..this is my first post on this site..im from Bahrain ( Middle East)..i owna Landrover Discovery II 1994 Model
My Problem is that suddenly my car started heating up..the temperature needle went way up till H...i have got it checked by Radiator Specialists..but they cant answer my problem..i have been reading this forum for a long time so i hope that my question will be answered here
Oh and bye the way its a 3.9 Petrol Engine
Old Apr 7, 2008 | 08:26 AM
Default RE: Landy Heats UP like Hell
Do a coolant pressure test to see if you have a coolant leak or failing head gaskets.
Replace the t/stat, make sure you bleed the air from the coolant system.
Check and make sure your main fan is working properly as well as the electric fan in front of your radiator.
Old Apr 7, 2008 | 09:16 AM
ather90's Avatar
5th Gear
yes i have tried changing the Thermostat..also flushed the coolant..what do u meen by "bleed air from the coolant system"..and the main fan is also working
Old Apr 7, 2008 | 12:00 PM
How about your electric fan, is it coming on?
Do you have a plug on the top of your radiator, have you ever removed it then filled your coolant bottle till coolant comes out through the plug hole?
Old Apr 7, 2008 | 12:20 PM
ather90's Avatar
5th Gear
if u are talking about the FAN in the front..then yes it is...as for the plug..i have removed both the plugs (up and down).and then filled the coolant bottle until the water comes out..i have even hosed the entire radiator
Old Apr 7, 2008 | 02:18 PM
Then if you are still getting hot, I would look at a coolant pressure test to see if you are moving into a head gasket issue.
Washington Rover
Jan 12, 2014 08:10 PM
Roverrocks
Jan 1, 2014 11:45 PM
desertrover97
Jun 14, 2013 11:25 PM
Deltahf_2
Nov 4, 2011 11:54 AM
MAA3057
Oct 22, 2007 01:05 PM
