Largest Tire On Stock 16 in Rims - Disco 2
Old Nov 5, 2018 | 05:58 PM
droddisco's Avatar
7th Gear
Question Largest Tire On Stock 16 in Rims - Disco 2
Have a 2000 Disco 2 that has SLS and would like to know what the largest tire I can put on the 16in stock rims without putting in a lift kit or cutting/removing anything off the vehicle. Appreciate any suggestions and input and also on economical brands and vendors. Thanks!!
Old Nov 7, 2018 | 11:23 AM
rcdoeshair's Avatar
I have 265/70 16 on mine .If you turn real sharp it will rub a little but that's it. Also, you'll have to turn your spare tire mount upside down in order to make room for the new tire .
Old Nov 8, 2018 | 12:21 AM
MrHSE7's Avatar
Im thinking it would have to be just under 32" in Outside Diameter to fit.
Old Nov 23, 2018 | 06:47 PM
Wesley Lueders's Avatar
Yes, I run 265/70 16's with just a touch of rubbing on sharp turns on stock suspension I believe that is a 30.5 inch OD.
eskiltell
Tires
Mar 30, 2018 03:48 PM
KingKoopa
Jul 28, 2016 09:20 AM
robersonb
Feb 22, 2013 01:14 PM
FlyingZebra34
Aug 31, 2012 07:33 PM
Intellius
Sep 24, 2011 10:42 AM
