Leak Around Roof Rack
Old Feb 13, 2008 | 12:02 PM
DuplinDisco's Avatar
Default Leak Around Roof Rack
A found a small wet area at the headliner above my back driverside door. I sprayed the Disco with water and it appearss to be coming from where the roof rack attaches to the top. Is this common? Am I going to have to remove the headliner to fix it?
Old Feb 13, 2008 | 02:32 PM
raid13's Avatar
Default RE: Leak Around Roof Rack
see this thread
Water Leak -- HELP! - 1/22/2008 10:26:43 AM
Old Feb 13, 2008 | 02:39 PM
ORIGINAL: raid13
see this thread
I think the link is missing
Old Feb 13, 2008 | 02:56 PM
Ok..I found the article but my leak is at the back drivers side door. Went ahead and pulled the headliner out a few minutes ago. Going to remove the roof rack (it needs painting anyway) and try to reseal.
Old Feb 13, 2008 | 03:29 PM
Ok..I did a quick pic to help someone else that may have the same problem down the road The headliner was slightly wet right above the back side door. I originaly sprayed the water hose at the safari window but determined it wasn't leaking. After removing the headliner I figured out that it was coming from where the roof rack bolts to the roof. I stuffed a paper towel around the nut..sprayed the roof with water and walla..the leak.
The section I labeled "water" was where the headliner was wet...the water just traveled down the channel.
Old Feb 13, 2008 | 04:48 PM
Thank you for the pics. Now I know what to look for if it happens to me.
Old Feb 13, 2008 | 04:51 PM
Camdisco24's Avatar
Thats really strange that it comes in that easily. Do you have any ideas on how you're going to seal it?
Old Feb 13, 2008 | 05:02 PM
ORIGINAL: Camdisco24
I'm just going to remove it and clean it well where it seals before I put it back on. Probably apply a bit of silicone around the seal. Once its on I'll just test it again until its right. At least thats what I am hoping.
Oasisplayer311
May 7, 2015 09:42 PM
Oasisplayer311
May 3, 2015 03:00 AM
mx468
Sep 19, 2012 07:21 PM
dinandan
Jul 4, 2006 10:43 AM
dinandan
Jun 22, 2006 07:22 PM
