Leak Around Roof Rack
A found a small wet area at the headliner above my back driverside door. I sprayed the Disco with water and it appearss to be coming from where the roof rack attaches to the top. Is this common? Am I going to have to remove the headliner to fix it?
Ok..I found the article but my leak is at the back drivers side door. Went ahead and pulled the headliner out a few minutes ago. Going to remove the roof rack (it needs painting anyway) and try to reseal.
Ok..I did a quick pic to help someone else that may have the same problem down the road The headliner was slightly wet right above the back side door. I originaly sprayed the water hose at the safari window but determined it wasn't leaking. After removing the headliner I figured out that it was coming from where the roof rack bolts to the roof. I stuffed a paper towel around the nut..sprayed the roof with water and walla..the leak.
The section I labeled "water" was where the headliner was wet...the water just traveled down the channel.
ORIGINAL: Camdisco24
Thats really strange that it comes in that easily. Do you have any ideas on how you're going to seal it?
Oasisplayer311
May 7, 2015 09:42 PM
Oasisplayer311
May 3, 2015 03:00 AM
mx468
Sep 19, 2012 07:21 PM
dinandan
Jul 4, 2006 10:43 AM
dinandan
Jun 22, 2006 07:22 PM
