THE LEAK IS BACK. Need ideas
Old Nov 9, 2012 | 05:47 PM
ashtray's Avatar
Angry THE LEAK IS BACK. Need ideas
Okay everyone. So I bought a new lower windshield cowel. That was okay because I needed one anyway...but it didn't fix my problem. I then crawled under the truck and realized my AC drain lines were COMPLETELY clogged. I unclogged them very well and tons of water came out and I thought the problem was fixed. I used the AC a bit from then on and did not notice anything substantial...until today. I got back into my truck after a 15 minute highway drive to the mall. Once I was done at the mall I got back into the truck and it smelled like "WET" and "nasty". I check the passenger floor board and there it is, a big old wet spot about the size of a brand new roll of paper towels in diameter. What could it be? I'll do anything to stop this leak. It is the only thing making me fear driving the truck knowing I cannot use the AC because of a leak. What do you all think?
Best,
Ashtray
Edit: By the way. The AC was NOT on AUTO and it was on recirculate on LO and at 3 bars of power(:::__)
Old Nov 9, 2012 | 07:10 PM
Only 2 things will cause that plugged a/c drains, still or leaking sun roof drain, but that water won't smell like the a/c water will.
Old Nov 9, 2012 | 07:53 PM
ashtray's Avatar
It has not rained and I have not washed the truck. I am positive it is the AC. What else can I check that might be disconnected or clogged, Disco Mike?
Old Nov 9, 2012 | 10:36 PM
Have you reamed out the a/c drains with pipe cleaner or some such?
Maybe there is a spider nest or whatever up inside where you cant see/reach with just your hands?
Have you made sure the nipples on the drains do not have any dirt on them?
Old Nov 9, 2012 | 11:35 PM
ZGPhoto's Avatar
I cut a little bit off my ac drain nipples(not suggested, but worked fine for me)
Old Nov 10, 2012 | 01:14 AM
One of mine looked like a "dirt dauber" wasp had tried to build a mud nest on it, and when I poked this off with a stick I was rewarded with a envigorating shower in my face of scum water. Um, um, um, tasty.
Important point, there are two drains.
Old Nov 10, 2012 | 10:01 PM
ashtray's Avatar
How do I ream out the a/c drain lines and what cleaner do you recommend?
Yeah I did this. A ton of water just poured all over me too.
Old Nov 10, 2012 | 11:16 PM
Pipe cleaner, did you ever smoke a pipe? Your dad? Grandfather?
Do you know the thing they used to clean it out with? That stiff fuzzy thing?
I dont know what its called now, you can but it at a hobby shops.
Take that and ream out the a/c drain holes.
Old Nov 10, 2012 | 11:22 PM
br0keit's Avatar
They're still called pipe cleaners though now they're mostly used for arts and crafts. Ah the glory days of kindergarten.
Old Nov 10, 2012 | 11:27 PM
ashtray's Avatar
Ohh yes I have smoked a pipe and so has my dad. I suppose I'll pick some of these up soon and do a better job on that passenger side drain line.
tigertrakstar1
Mar 5, 2014 04:13 PM
hubie
Jun 22, 2010 05:41 PM
EstorilM
Feb 22, 2010 12:20 PM
yukonridin23
17
Aug 8, 2009 02:06 PM
rgrizzard
Mar 6, 2008 10:16 AM
