leak over drivers seat
I have never seen a clogged drain on the D1 or D2. Not saying it can not happen but I have never seen it. But I have seen the attachment point for the drain come loose. The factory sealer will weaken and the corner where the drain tube attaches to the tray will leak. That needs to be resealed and the attachment point for the roof rails need to be resealed and tightened. Also check the seal of the sunroof assembly to the roof.
I believe all of us have that problem. If you need a quick temporary fix, get a removable silicone and caulk outside then fix during summer. Theres a lot to remove just to check that leaking sunroof.
LordOphidian
07-13-2006 08:55 PM
