leak over drivers seat
Old Jan 18, 2018 | 04:29 PM
sophiabrinton's Avatar
Default leak over drivers seat
possibly through sun roof? not sure. has anyone had this problem?
Old Jan 18, 2018 | 04:33 PM
Sixpack577's Avatar
Sunroof drain is probably clogged.
Remove the headliner and clean the drains.
Old Jan 18, 2018 | 04:45 PM
alpinacsi's Avatar
I have never seen a clogged drain on the D1 or D2. Not saying it can not happen but I have never seen it. But I have seen the attachment point for the drain come loose. The factory sealer will weaken and the corner where the drain tube attaches to the tray will leak. That needs to be resealed and the attachment point for the roof rails need to be resealed and tightened. Also check the seal of the sunroof assembly to the roof.
Old Jan 18, 2018 | 05:01 PM
LR03NJ's Avatar
I believe all of us have that problem. If you need a quick temporary fix, get a removable silicone and caulk outside then fix during summer. Theres a lot to remove just to check that leaking sunroof.
SolbergFanBoi
Mar 5, 2012 07:05 PM
sickrangerover
Dec 10, 2011 04:15 PM
sickrangerover
Aug 25, 2006 06:57 PM
LordOphidian
Jul 13, 2006 08:55 PM
thesaintnr1
Feb 7, 2006 08:16 PM
