Leak From Somewhere
Old Oct 5, 2014 | 11:26 AM
Vai2kdna77's Avatar
Default Leak From Somewhere
Hey all- I noticed today that I am leaking what looks to be antifreeze from just below the passenger valve cover gasket. I does not look to be mixed with oil. There are NO visible signs of sweet smelling smoke from the tailpipe, no milky oil mixture, and no overheating. I added two pics below. Any suggestions would be great.
NOTE- The photo referenced is the passenger side O2 Sensor pigtail/ connector as it rests close to the block, near the rear of the header from that side.
I am at a loss and praying it is not a head gasket or blown head.
Thank you all once again!
Kevin
Old Oct 5, 2014 | 11:31 AM
RicketyTick's Avatar
Are you loosing coolant? Do you have to add coolant to the tank often?
Old Oct 6, 2014 | 06:03 AM
drowssap's Avatar
possible head gasket or intake manifold gasket leak, you need to pressure test your system to find out which.
Old Oct 6, 2014 | 08:13 AM
Vai2kdna77's Avatar
Ok, I can take it to autozone or advance and pressure test it?
I do fill it every once in a while, but it is so random. I keep getting the trickle sound and I undo the expansion tank and allow it to get the air out.
So- It appears to need a pressure test, and that should tell me what I need.
Again- Looking up things on the forum and google- other than a coolant leak at random times, there are NO signs of typical Head Gasket failure.
Thank you all for this forum- it is truly appreciated and a life saver.
Old Oct 6, 2014 | 08:34 AM
drowssap's Avatar
the store will not do it for you, they will lend you the tester you will have to do the test yourself or bring it to a shop and pay them.
its a pretty simple test most times, install the tester pump up to 18 psi and start looking for the leak, in your case you will want a flashlight and mirror.
94svt50
Nov 3, 2013 04:27 PM
GLOCK3462
Aug 5, 2011 07:53 PM
Eak69
Feb 22, 2011 09:12 PM
adowgiert
May 7, 2007 04:07 PM
