Leak in the sunroof....or Roof Rack?
When it rains pretty heavy, I'm noticing a few water drops coming down from my passenger side over-head visor...every now and then I see it on the driver side as well. I feel around the sunroof and don't notice any wetness, the location of the water seems like it might be coming from the roof rack bracket. Any ideas how I could seal this? I need a quick fix, cause I'm going out of town for a while.
2000 Disco II
2000 Disco II
RE: Leak in the sunroof....or Roof Rack?
Several of us are having this issue. What year is your truck? I posted this complaint a week or so ago. The most common issue is usually the sunroof drains apparently. They either become disconnected or clogged. If you remove the handles above the doors you can pull the headliner down enough to check the drains. Mine are intact, so I triedsome grease remover sprayed in the tracks / drains...see if it works.
dinandan
07-04-2006 10:43 AM
dinandan
06-22-2006 07:22 PM
