Leak in the sunroof....or Roof Rack?
Old Jun 14, 2007 | 11:03 AM
crainface's Avatar
Default Leak in the sunroof....or Roof Rack?
When it rains pretty heavy, I'm noticing a few water drops coming down from my passenger side over-head visor...every now and then I see it on the driver side as well. I feel around the sunroof and don't notice any wetness, the location of the water seems like it might be coming from the roof rack bracket. Any ideas how I could seal this? I need a quick fix, cause I'm going out of town for a while.
2000 Disco II
Old Jun 14, 2007 | 11:25 AM
jdelp's Avatar
Default RE: Leak in the sunroof....or Roof Rack?
Several of us are having this issue. What year is your truck? I posted this complaint a week or so ago. The most common issue is usually the sunroof drains apparently. They either become disconnected or clogged. If you remove the handles above the doors you can pull the headliner down enough to check the drains. Mine are intact, so I triedsome grease remover sprayed in the tracks / drains...see if it works.
Old Jun 14, 2007 | 12:43 PM
crainface's Avatar
it's a 2000 disco II
EstorilM
May 8, 2022 12:39 AM
Juergen33911
Jun 19, 2013 12:49 PM
BigRed98
Jun 21, 2010 12:30 AM
dinandan
Jul 4, 2006 10:43 AM
dinandan
Jun 22, 2006 07:22 PM
