Leaking ace pipe pin hole
Old Apr 6, 2020 | 06:42 PM
Gareth1988's Avatar
Default Leaking ace pipe pin hole
Right I have a leak in a corroded pipe on the front really need to get it sorted cheap as possible any easy fix ? Thank for reading
Old Apr 8, 2020 | 09:07 AM
redrover75's Avatar
If it is a pin hole, I would clean it really well and JB Weld it.
Old Apr 8, 2020 | 11:03 AM
Gareth1988's Avatar
Do you think that will work?
Old Apr 8, 2020 | 11:19 AM
mollusc's Avatar
Would he have suggested it if he didn't?
Old Apr 8, 2020 | 02:54 PM
XRAD's Avatar
Well where is it leaking from?? If you have enough metal pipe to get about 2" of hose purchase off the banjo and the other end fitting, then just get a length of high pressure hydraulic hose, cut to overall length, and clamp on to pipe remnants. use two or 3 hose clamps at each end.
Bananar1der
Nov 29, 2019 03:53 PM
difrentbob
Apr 12, 2016 04:04 PM
cfp_ivan
Dec 20, 2011 10:34 AM
scottg1974
Aug 8, 2010 10:57 AM
johndixon1967
Oct 8, 2009 04:22 PM
