Leaking ACE Valve block fixed!!
Old Dec 15, 2020 | 07:25 AM
H Hill's Avatar
Default Leaking ACE Valve block fixed!!
My ACE block on my '00 Discovery 2 was leaking, rather badly. 274K on the truck, everything working great, except the valve block leak. When evaluated by my local indy shop, they said that the valve block was the problem, that pulling the lines to replace seals may not fix the leak, due to deterioration of the block. The new unit was way too much so I searched and found a replacement. I found Design and Development Engineering, LTD in the UK.
https://www.designdevelopmenteng.co....ded-p110170661
This company rebuilds and upgrades the ACE Valve block by machining hydraulic hoses with all new seals, switches and solenoids. All I had to do was remove the old valve block, (cleaned and color coded the steel lines with colored electrical tape), install the new unit, then cut and attach the new hoses. Works fine and no more leaks.
New upgraded ACE valve block
Installation compete.
Everything worked great and again, no more leaks!
Old Dec 15, 2020 | 04:46 PM
nashvegas's Avatar
Cool. So the pipes on the truck... Do you cut them shorter ?
Old Dec 16, 2020 | 02:21 PM
T-rex's Avatar
Looks good! I went the cheap way and did the modification myself
Old Dec 17, 2020 | 02:15 PM
H Hill's Avatar
Yes, I used a small tubing cutter to cut each pipe after I bolted on the new valve block. I had used different colored electrical tape and color coded each pipe, as well as each hose on the new unit, just to make sure I made all the correct connections.
Tubing cutter
Old Mar 31, 2021 | 04:53 AM
charlielinder's Avatar
Are you using hoses all the way to the RAM's? Or have you connected the old pipes?
T-rex
Sep 1, 2021 06:29 AM
difrentbob
Apr 12, 2016 04:04 PM
justinthorpe
Oct 8, 2014 02:26 PM
niknak
Mar 11, 2013 10:11 AM
tbuckt007
Sep 21, 2010 01:44 PM
