Leaking disco 2
Old Aug 18, 2022 | 11:53 AM
Brigh04disco2's Avatar
8th Gear
Default Leaking disco 2
I fixed up whole my car and got it insured now it started leaking from the bottom there are some pictures but idk where it comes from... Anybody that can help me..
Old Aug 18, 2022 | 02:58 PM
Extinct's Avatar
Likely the TC case center shaft o-ring - do a search and you should get plenty of info.
Old Aug 18, 2022 | 04:47 PM
zski128's Avatar
Also check that the breather tube (thin black plastic) in the engine compartment (passenger side rear) is not melted closed. There are two in that area, one for the transfer case and one for the transmission.
Old Aug 19, 2022 | 11:45 AM
8th Gear
Is it a difficult job or its okay bc i can imagine you will have to take the whole tranfser case out. Also i have a leak at was seems to be where the engine meets the transmission ofcourse im not sure bc the oil collects to one point..
Old Aug 19, 2022 | 02:34 PM
Discorama's Avatar
I have a TC leak too and just wipe it clean from time to time. As long as it doesn't make a mess on the driveway it's not worth the effort to replace that seal. I check the oil level from time to time and I add some if needed. Last time I added 3 ounces after 20k miles.
Old Aug 20, 2022 | 07:18 AM
8th Gear
Unfortionally mine has a decent size of pooling underneath it so i think i'm obligated to fix it....
Old Aug 20, 2022 | 11:20 PM
Land Rover Doc's Avatar
Torque Converter to front pump seal or leaking converter. The fluid on your pictures is red so it is transmission fluid. Take off the little inspection plate on the bottom of the bell housing and see if transmission fluid comes out. If so it is that seal or the torque converter leaking. That will necessitate a transmission and transfer case removal and repair of the seal and or torque converter. I'm in the middle of the same repair. I replaced that front pump seal and it's still leaking so now I have to take it back out and pressure test my torque converter.
Old Aug 21, 2022 | 05:07 AM
8th Gear
I went under my car again... And i still have no clue what to fix to get rid of these leaks.. I checked my breather tubes which already seemed to be rerouted. I let the car run and then there is no leakage and when i turn it off still nothing but over the case of some hours or days the oil will reappear on the same places. The pictures above are only engine oil leakages bc its a deep black color but the pictures at the beginning of the post are for sure transmission oil seeing that its a reddish colour. I am out of ideas now..
Sabbe
Oct 14, 2021 08:11 PM
Adesapigne
Oct 19, 2020 11:45 AM
Jaygoldmaxx
Jan 26, 2020 10:01 AM
loanrangie
May 17, 2016 04:36 AM
jeremandre
Sights N Sounds
Mar 13, 2016 05:34 AM
