Leaking front cover
Old Aug 24, 2015 | 09:21 AM
Joemamma1954's Avatar
Default Leaking front cover
If you have a Disco 2, that did not come with an oil cooler. Check the two plugs that were installed in the front cover in place of the oil cooler lines. Both of mine were hand tight and neither had a o-ring. One is between oil filter and oil pan, the other is above oil filter on passenger side. Both will take 7/8" socket or metric equivalent. Mine have been leaking since I purchased, after installing oem oil cooler, My oil leak disappeared. I had purchased front cover gasket, seal, timing gears and chain, oil pump, pan gasket for install. Am putting that off until I have some spare time and want to get dirty.
rally1
Feb 22, 2022 06:22 AM
LADEROUTE
May 16, 2014 12:17 AM
tmtegt
Mar 20, 2013 07:31 AM
Disco Ed
Feb 2, 2011 04:04 PM
DeepBlueWater
Sep 27, 2007 07:22 PM
