broken axle?
Old Aug 5, 2008 | 10:08 PM
fastbullet10's Avatar
Default broken axle?
I have a 97 discovery its been making a popping sound in the front drivers side for a couple of days.Tonight I went to pull out of the driveway when it make alot of noise when I turned the wheel real far to one side.Now it will not move at all when you put it in gear you can hear a feel a noise behind the front tire.It will not move in 4high or low.any idea what Im looking at and how bad the repair might be
Old Aug 5, 2008 | 11:05 PM
hazletbassist89's Avatar
Default RE: broken axle?
I'm not exactly sure what that could be, but just in case I have a feeling you should get some wallet bandages ready...
Old Aug 6, 2008 | 01:05 PM
http://www.roverparts.com/Parts/STC3050.cfm
The axles on these are pretty easy to replace. I've never done it but it is pretty straight forward.
Have you checked your differental fluid to make sure that it isint low? Drain that and see if big chunks come out, maybe you broke your front diff. Jack up the front of the trk, can you turn the wheels by hand?
Old Aug 7, 2008 | 12:35 AM
The axle is broke. We took it apart today. it took about 10 minutes to get it out. Not hard at all. Now i just have to replace it. It was shattered. Thank for your help. I found a hole front end axles and all for 350. Thats good compaired to what land rover was going to charge me. Almost 700 bucks...
Old Aug 7, 2008 | 09:56 AM
NiteTrain's Avatar
make sure you open up your diff and get ALL metal pieces out if not you'll have more problems down the road.
cationmoted
Oct 19, 2012 07:39 AM
kman3786
Jun 6, 2010 01:01 PM
DucsNDirt
Jun 15, 2009 09:20 AM
DiRanged Rover
May 26, 2006 12:39 PM
DiRanged Rover
May 24, 2006 07:36 PM
