Leaking seal, Which gasket is it?
Old Jan 8, 2010 | 07:23 PM
malmberg's Avatar
Default Leaking seal, Which gasket is it?
I just got done changing the oil when I started to rotate my tires. When I pulled off the passenger rear wheel I noticed what looked like grease around the caliper and rear of the rotor. I checked my rear diff fluid and it didn't seem bad. I haven't noticed any leaks in the driveway so I assume that it has just started. My question is which seal would I need to replace to fix this problem?
Old Jan 8, 2010 | 07:34 PM
http://www.roverparts.com/Parts/FTC4919G.cfm
Old Jan 8, 2010 | 08:05 PM
lipadj46's Avatar
Just bought 2 for my truck, you will need to take off your rotors, remove the 4 hub bolts and pull out the entire axle/hub assembly, replace the o'ring then put everything back together. I had leaks like that that stopped but I figure I would replace the o'rings anyhow.
Old Jan 9, 2010 | 06:47 AM
Rovin4life's Avatar
aint the orings,
its the entire hub seal.
need a new hub.
Old Jan 9, 2010 | 08:11 AM
lipadj46's Avatar
Well he will not know that until he gets them out and takes a look.
Old Jan 9, 2010 | 09:10 AM
Rovers long history with the hubs say it will be the hub that needs to be replaced along with a new o-ring.
Make sure that you change your gear oils while doing this, 7 quarts of a 75W/140, for the higher mileage, will take care of both diffs and the t/case.
Old Jan 9, 2010 | 02:53 PM
malmberg's Avatar
Thank you all for your responses. I am currently running royal purple that has about 8000 miles on it. I will have to rip into it more to see where it is coming from. Where is the best place to get hubs from?
Old Jan 9, 2010 | 06:50 PM
www.autosportsunlimited.com
www.roverlandparts.com
www.atlanticbritish.com
Old Jan 9, 2010 | 07:50 PM
lipadj46's Avatar
Don't be afraid of used hubs. Justin at lucky 8 can get used hubs as new ones are ridonkulous $$$. I just bought a rear one from him with the ABS sensor for $120. Also call roverguy.com. This ebay dude has used hubs too and a couple ABS sensors:
He will take $50 if you use the make an offer button
http://cgi.ebay.com/ebaymotors/ws/eB...K%3AMEWAX%3AIT
outdoor7or24
Dec 22, 2014 09:31 PM
outdoor7or24
May 21, 2012 08:34 AM
s10lowrider1994
Feb 3, 2012 08:57 PM
yloDiscoII
Feb 10, 2010 10:03 PM
01 Discovery
Dec 1, 2006 12:07 AM
