Leaks!
Old Dec 29, 2017 | 04:32 PM
Berenice.amezcua17@gmail.com's Avatar
Default Leaks!
Engine oil leaking from drivers side. I'm sure it's engine oil, it looks black. The leaks it leaves overnight are about the size of my hand. I just got new head gaskets a year ago. I am usually on top of my oil changes, but this last oil change happened 300 miles after recommended mileage. Just did the oil changenlast week, and am still seeing leaks. Any clues? Heellllp! I drive a 2002 landrover discovery with 143k miles on it.
Last edited by Berenice.amezcua17@gmail.com; Dec 29, 2017 at 04:35 PM. Reason: Make and model
Old Dec 29, 2017 | 05:37 PM
Extinct's Avatar
Drivers side; could be power steering, brake fluid, or engine oil. If it is engine oil the breather baffle in the passenger side valve cover is plugged - needs to be removed and cleaned or replaced. If it is power steering fluid - need a gasket for the pump. If it is brake fluid, needs a master cylinder or master cylinder repair kit.
Where is the spot relative to the DS front wheel?
Old Dec 29, 2017 | 09:28 PM
Front driver side oil leak could also be the oil cooler line leaking. That is what it was on mine.
Spencerfitch
Sep 27, 2020 12:17 PM
FlyingZebra34
Apr 22, 2013 12:07 AM
Derek
Feb 17, 2013 07:37 PM
discoboy
Dec 20, 2012 02:24 AM
bmwrovers
May 23, 2005 01:02 PM
