Leaky Brake Master Cyl - replace brake servo?
Old Jul 9, 2012 | 05:24 PM
SolAeon's Avatar
3rd Gear
Default Leaky Brake Master Cyl - replace brake servo?
Hello Gents-
Thanks for everyone's great input to this forum.
Among various other issues with my D2, I have a leaky brake Master Cylinder. I need to either replace the entire assembly (seen them for about $180-$250) or get a repair kit (seen them for about $75-$85).
Does anyone here have experience/opinions about either approach? Some folks don't recommend seal-repair kits.
Is there any trick to replacing the master cylinder?
Lastly, a mechanic suggested that I replace the Brake Servo Assembly, as (part of?) the reason that the engine runs rough (hesitates when gas pedal applied) and related to my squishy brakes (which I think is simply function of leaking master cyl and air in the brake lines) -- Has anyone here experience/opinions about replacing the Brake Servo Assembly?
Thanks,
SolAeon
Old Jul 9, 2012 | 11:30 PM
BrandonS's Avatar
If it isn't a daily driver I would personally pull your master cylinder off and take it apart. If the metal parts inside don't show wear I'd try the repair kit.
If it's a daily I suppose you could order both and return one, or order just your repair kit and gamble a bit.
Old Jul 10, 2012 | 09:05 AM
The servo does not need to be replaced as long as you did not leak brake fluid into it.
FlyingZebra34
Apr 18, 2014 02:00 PM
landy90
Defender
Oct 11, 2012 08:34 AM
pottzie
Sep 2, 2012 03:06 PM
Cosmic88
Dec 13, 2010 08:25 PM
jneil
May 25, 2010 09:31 AM
