leaky leaky brake resoviour
Old Apr 16, 2014 | 10:15 PM
FlyingZebra34's Avatar
Default leaky leaky brake resoviour
So I noticed today while swapping out the check valve that I'm leaking brake fluid and it appears that the resoviour is loose and can move and it looks like a slow leak from here.
Is this repairable?
I've never worked on this part of the brake system..
Old Apr 17, 2014 | 12:44 AM
Dane!'s Avatar
Yep, rebuild kits are available. Its easy and cheap(er).
The bleed procedure is honestly harder than rebuilding it.
Old Apr 17, 2014 | 02:53 PM
How difficult is it? I've blead the system for the ABS block, I know you can't have any air in the master cylinder but how hard is that to achieve? I don't have the money for a new one at the moment -.-
Old Apr 17, 2014 | 03:34 PM
primussucks's Avatar
rebuild kit is $100 from stealership... probably found slightly cheaper online
Old Apr 17, 2014 | 03:47 PM
ZGPhoto's Avatar
$79 hit me up....
Old Apr 17, 2014 | 04:05 PM
mattmo78's Avatar
Zebra, it's super easy to do. I just rebuilt mine this winter. Took about 40 minutes start to finish. There is a good write-up on here with pictures that'll walk you through it.
It really was harder to do the brake bleed than it was to switch out the reservoir. Which means it's really easy to do.
Old Apr 18, 2014 | 02:00 PM
Well I'm glad it's doable. I'm pushing through a few projects right now so hopefully I can get to it within a week or so.
SolAeon
Jul 10, 2012 09:05 AM
weeeeeeeeeeee
Jan 7, 2007 05:36 PM
dillhole
Nov 12, 2006 03:35 PM
Benhamtroll
Jun 21, 2005 09:41 PM
DIMISA1977
Apr 20, 2005 09:33 PM
