LED light bar
LED light bar
I have the TJM from bumper and I am ready to replace the 7" round fog lights with a LED light bar. I found one that I think will do the trick, however I am not sure if 126W is too much... I have a feeling I will need to up the fuse already in place for one that can handle more? Is this correct? I don't want to damage anything, the (LED light bar) appears to be a plug and play. The link to the light bar is below. Thank you in advance.
20" 126W CREE LED Light Bar 8820LM Flood Spot Lamp 4WD Driving Offroad Lights | eBay
126 Watts worth of LED's ........................ you'll 'burn' them to death with that lot
I'm sure the LR system will cope via a good relay, adequate wiring and quality switch to it but fuse it separately..................... just in case
PS. Quickly doing the calcs 126W at 12V it's only 10.5 amps therefore IMO I'd use a 15 or 20 amp fuse but ensure the wiring and relay is rated heavier than the max load.
