Left Front rake Line replacement Questions
Old Dec 18, 2009 | 11:05 AM
andrew12159's Avatar
Default Left Front rake Line replacement Questions
OK so I started to leak fluid from the middle of the drivers side rubber brake line and I am taking this D1 on a 800 mile trip next week. My question is what tools do I need to do this job. Its 8 degres out and I want to have everything setup before I start. Thanks.
Old Dec 18, 2009 | 12:19 PM
If you have one line leaking, you should replace all, both front and rear, cause when one fails, the rest are soon to follow.
No special tools are requires, a couple open end wrenchs should be fine.
Buy 3 to 4 pints of DOT 4 brake fluid and do a complete bleed when done installing the 4 new lines.
Old Dec 18, 2009 | 12:56 PM
antichrist's Avatar
I highly recommend one of these, they work great.
http://www.eastwood.com/ew-brake-for...ol-pliers.html
You'll also need a bubble flare kit:
This works well.
http://www.summitracing.com/parts/OTC-4504/
Then go to NAPA and get a roll of copper clad brake line tubing, 3/16"/4.75mm. This assumes you can reuse your fittings. If you can't, I'd order the fittings and line from http://www.fedhillusa.com/ if you don't have an import parts place near you where you can get the correct fittings.
Doh! I missed it was the flex line. Yes, replace them all, and all you need is a set of flare nut wrenches.
RTE has a good price on the teflon lined stainless steel wrapped ones.
Old Dec 18, 2009 | 08:05 PM
I dont have time to do all 4 right now. I need the truck for a xmas trip. I bought 1 front line and will upgrade the rest when its not 4 deg out. anyone know what size wrenches I need? Thanks for the help and merry xmas!
NoogaRover
Apr 3, 2015 06:10 PM
ServerGuy
Apr 3, 2015 07:51 AM
Colorado David
Jul 21, 2014 03:19 PM
SkymonkeyONE
Jan 7, 2013 02:02 PM
JerrodSteph
Jun 12, 2011 06:04 PM
