Left Front Spring Broken
Old Oct 6, 2009 | 12:35 PM
mwindth's Avatar
Default Left Front Spring Broken
As I was doing some maintenance, I noticed my left front spring is broken. Is it ok to replace just one of the springs? Will it throw the balance or steering off? I noticed that I can buy just one spring from Atlantic British for about $88.
Also, any special tools needed to replace?
The truck has 55K miles on it and stock.
Thanks!
Old Oct 6, 2009 | 12:57 PM
NiteTrain's Avatar
your old springs have sagged some in 55K miles so there will probably be a height difference. This is a good excuse to buy new lifted springs.
Old Oct 6, 2009 | 01:09 PM
jycsalas's Avatar
Replace BOTH... Do it right.
Old Oct 6, 2009 | 01:37 PM
mwindth's Avatar
Yes...you are correct jycsalas...I just ordered a kit from Atlantic British with both front springs
Someday NiteTrain I will get a lift...
Any special tools needed?
Thanks!
Old Oct 6, 2009 | 01:43 PM
98roverguy's Avatar
Thanks!
Here you go. http://www.youtube.com/watch?v=Pkz0NTMFeYY They do the front end later in the video.
Don't let the lovely assistant distract you.
Old Oct 6, 2009 | 01:55 PM
mwindth's Avatar
OK...I need an assistant like yours!
Old Oct 6, 2009 | 02:47 PM
NiteTrain's Avatar
yeah seriously! I want to work in that shop
Old Oct 7, 2009 | 10:44 AM
Exactly what springs did you order, be specific?
If you don't replace all 4, the rear will be sitting low and you should/must replace the shocks also cause they are shot.
Old Oct 7, 2009 | 10:25 PM
mwindth's Avatar
Hey Mike,
I bought two of these...already on order: http://www.roverparts.com/Parts/REB101330.cfm
The shocks feel fine and the rear-end does not sag. At 55K miles and me only driving about 6K per year, I figured it should be fine.
I also figured since the front-end is a little lower in the front naturally, maybe the new springs will level it out. If not I will buy the rear springs.
Old Oct 8, 2009 | 02:44 AM
malmberg's Avatar
Holy S**t. Why are you wasting your money on those springs when the OME springs are cheaper. I hope that didn't come out wrong but if you are planning on a lift in the future these springs are a big waste of money in my opinion. And if you do have to replace the rear springs b/c of how it sits you are already past the halfway point for the lift. Good luck
