Left rear wheel sensor fault
Old Jul 30, 2016 | 06:12 PM
brooksa's Avatar
Default Left rear wheel sensor fault
Here's one for the group,
Had a leaky axle seal at left rear wheel so replaced O ring and now throwing sensor fault? Pulled sensor back out, cleaned and replaced and still throwing fault at about 20 mph. Did I screw up sensor some way? Any thoughts?
Old Jul 31, 2016 | 05:12 PM
OffroadFrance's Avatar
The sensors are robust but the ABS reluctor ring is probably gummed up with oil, grease and crud or it could be a plug/socket fault on the sensor. You can try blasting the reluctor ring with an air line through the sensor hole and turn the hub/wheel around whilst doing this. Obviously it will need to be on axle stands.
Old Jul 31, 2016 | 08:11 PM
brooksa's Avatar
Thanks for the reply OffroadFrance,
It did have a fair amount of crud that I cleaned and gave it a shot of air, took a couple of tries but all good now, no fault!
Old Aug 1, 2016 | 04:37 AM
It's my pleasure sir
hossiena
Jul 18, 2013 10:48 PM
06Range
May 8, 2013 09:01 PM
workinghard1713
Apr 16, 2012 11:25 AM
twaszak
Jun 4, 2011 07:49 AM
