LEts talk Ball Joints 2003 D2
on
How many miles on your truck, do the ball joints pop or snap when turning and is the rubber seal cracked or leaking?
If any of these problems occur you would be wise to replace them all. I have one lower ball that has a torn rubber seal, pops once in a while, been that way for a couple of years and is still safe.
Dusty, wot - no 'go faster' NACA ducts, and they're so cheap.........![Wink](https://landroverforums.com/forum/images/smilies/Uh2vXQr.png)
No self respecting dude would have wheels without loads of NACA ducts on it doing absolutely..........eeerrrr..............nothing![Wink](https://landroverforums.com/forum/images/smilies/Uh2vXQr.png)
https://www.google.fr/search?q=naca+...w=1097&bih=605
2000 discovey II se7 100k Yoshimi. mods..dropped and chopped 3.75",hurst shifter, 22" dubs spin wheel things, hot tub on roof,curb feelers, hood bra,head light eye lashes,**** headliner, a bunch of colored lights underneath,mirrored ball dome light conversion, imitation air vents, 3'spoiler, silhouette ladies, real big speakers,gullwing doors,ground effects, saving for bounce hydraulics and a sexy hood ornament
I have the imitation air vents. I hope they don't clash
![EEK!](https://landroverforums.com/forum/images/smilies/bmHv6Xb.png)
![Big Grin](https://landroverforums.com/forum/images/smilies/lxvR5hR.png)
http://naca.central.cranfield.ac.uk/...a-acr-5i20.pdf
https://www.google.fr/search?q=pictu...w=1097&bih=605
Check carefully and follow Mikes advice before blundering into changing upper and lower swivel ball joints. There's a lot of hard work involved particularly if you find you didn't need to change them. Check methodically through your steering and suspension using a pry bar and also using an assistant moving the steering wheel back and forth a couple of inches whilst feeling each joint. In all honesty, unless you really have to, don't even go there with the ball joints.
thanks
David
TRIARII
01-20-2014 07:55 AM
expeditionnw
10-18-2013 10:54 AM
98roverguy
08-02-2010 05:28 AM
CandiMan
11-07-2008 10:57 AM
