LEts talk Ball Joints 2003 D2
Old Jun 10, 2014 | 11:48 AM
Yoops Racing's Avatar
Default LEts talk Ball Joints 2003 D2
Guys what type of mileage do the ball joints need replacing? Mine look like they may need to be replaced but the truck drives fine. I was told this is about a 12hr job is this correct? Are there better replacements than OEM?
thanks
David
Old Jun 10, 2014 | 11:51 AM
Racer X's Avatar
12 Hours?! LOL!
4-6 if you're doing both sides.
Heat and breaker bars are your friend, and a heavy hammer to unseat the hub from the spindle, and the spindle from the ball joints.
Old Jun 10, 2014 | 12:29 PM
dusty1's Avatar
As mentioned above 5ish hrs. Oem made it this long so...I don't know if you can do better. Cheap azz tool from hf worked for me.
Old Jun 10, 2014 | 01:20 PM
How many miles on your truck, do the ball joints pop or snap when turning and is the rubber seal cracked or leaking?
If any of these problems occur you would be wise to replace them all. I have one lower ball that has a torn rubber seal, pops once in a while, been that way for a couple of years and is still safe.
Old Jun 10, 2014 | 04:03 PM
OffroadFrance's Avatar
Dusty, wot - no 'go faster' NACA ducts, and they're so cheap.........
No self respecting dude would have wheels without loads of NACA ducts on it doing absolutely..........eeerrrr..............nothing
https://www.google.fr/search?q=naca+...w=1097&bih=605
2000 discovey II se7 100k Yoshimi. mods..dropped and chopped 3.75",hurst shifter, 22" dubs spin wheel things, hot tub on roof,curb feelers, hood bra,head light eye lashes,**** headliner, a bunch of colored lights underneath,mirrored ball dome light conversion, imitation air vents, 3'spoiler, silhouette ladies, real big speakers,gullwing doors,ground effects, saving for bounce hydraulics and a sexy hood ornament
Old Jun 10, 2014 | 06:02 PM
dusty1's Avatar
Oh, that's what they're called. Thanks.
I have the imitation air vents. I hope they don't clash
Old Jun 11, 2014 | 06:25 AM
Totally off topic..............again..................amazingl y, as you probably already know, there are very sophisticated calcs and uses of NACA ducts although modern science had proved them less effective than the lowly air scoops but NACA ducts have less interruption on aerodynamic effects..............not that affects anything on D2's or LR's in general as once described as the aerodynamic effect of 'forcing a house brick through air' or having the 'aerodynamic shape of a house brick' ..................bit like a red London bus...........
http://naca.central.cranfield.ac.uk/...a-acr-5i20.pdf
https://www.google.fr/search?q=pictu...w=1097&bih=605
Old Jun 11, 2014 | 06:36 AM
Check carefully and follow Mikes advice before blundering into changing upper and lower swivel ball joints. There's a lot of hard work involved particularly if you find you didn't need to change them. Check methodically through your steering and suspension using a pry bar and also using an assistant moving the steering wheel back and forth a couple of inches whilst feeling each joint. In all honesty, unless you really have to, don't even go there with the ball joints.
Old Jun 11, 2014 | 07:41 AM
86k miles - no popping but the rubber seal is sacked out and is smushed. I hear they last a long time as well but was curious more than anything on what the interval for replacement is.
thanks
David
TRIARII
Jan 20, 2014 07:55 AM
expeditionnw
Oct 18, 2013 10:54 AM
98roverguy
Aug 2, 2010 05:28 AM
CandiMan
Nov 7, 2008 10:57 AM
khuds308
Aug 19, 2007 04:43 PM
