Lets talk eng codes, service engine and Anti-Lock light
Old Nov 7, 2008 | 10:57 AM
CandiMan's Avatar
Default RE: Lets talk eng codes, service engine and Anti-Lock light
Success, my Anti-lock light is now off.
After searching on D-web this morning, I realized that only pre OBDII Disco's had the blue 4-pin connector. All OBDII Disco I's you have to jump terminals 5 and 15 on the data link connector. The data link connector is where you would plug in your scanner to read engine codes.
Anyways, I jumped terminals 5 and 15 with a paper clip,and with the ignition in the on position I readthe blink codes.One code was for the stop light switch and the others were for internal voltage supply.
The stop light switch I repaired few months ago and the internal supply voltage code was due to the pump hanress plug being slightly unpluged.
If you removethe paper clip while reading the code, it will erase that code. So that's what I did, read and erase each code, one at a time.Took for a test drive, light went out, all is well.
Now it's in the archives.
ls1morethanyou
Apr 24, 2014 05:09 PM
TRIARII
Jan 20, 2014 07:55 AM
expeditionnw
Oct 18, 2013 10:54 AM
98roverguy
Aug 2, 2010 05:28 AM
khuds308
Aug 19, 2007 04:43 PM
