Lift
Cheapest would be spacers. For two inches I'd recommend springs and shocks (Terrafirma or OME). It can actually be cheaper to go bigger though. You can get terrafirma 3" rear springs, move your factory rear springs to the front, and you'll still need shocks +2 shocks unless you can weld to move or modify the shock tabs. That's what I did.
With 3" you can run a 285/75r16 or a 275/70r18 which is a 33" tire.
