Lift advise
Old Jun 26, 2021 | 10:32 AM
redwhitekat's Avatar
Default Lift advise
Bought this rig yesterday been sitting for couple years, after looking a bit closer it’s got a terrafirma lift, not sure if it’s condition etc. Should I swap it to my 2004 ? Should I just check the shock movement ? The springs look rough but I don’t think they go bad right ?
Bad idea ? Also it’s 34 inches to bottom of wheel arch can anyone confirm if that matches to a 2 inch kit ?
Old Jun 26, 2021 | 11:53 AM
dswilly's Avatar
I have the TF MD 2" and mine sits at 37" with a 31.75" tire. I think the hub center to fender measurement is more accurate. My hub to flare is 21.5" on the front 20.5" rear. Those flares might have different profile compared to stock too.
Old Jun 26, 2021 | 02:46 PM
Took a peak under look at the springs
one is passenger side one is drivers side
what do you think is happening here ?
they look like they are different
Old Jun 26, 2021 | 03:53 PM
dswilly's Avatar
Here are mine L&R. They are different as drivers is supposed to account for driver weight.
Old Jun 26, 2021 | 04:48 PM
oh wow that looks exactly what I have
I think I will check the struts up and down movement and check the bearings
if I can use this it will be a major score
bumper 1700 cdn
snorkel 3-400 cdn
fender arch’s 400-500 cdn
lift 1200 cdn
got it for 1500
Old Jun 26, 2021 | 05:54 PM
Dave03S's Avatar
I like the color of both of them...
Old Jun 26, 2021 | 06:07 PM
the green is one of my favourite colours on these. The body and paint is so nice. Too bad it’s probably going to the scrapper soon
if I had land or room I would keep it
or I might sell it to someone they can still take parts and roof rack from it rear ladder cdl etc
if no one buys it I will strip it down abs pump window motors regulators window tracts bottoms fuses relays alternator etc all coming out for spares
Old Jun 28, 2021 | 06:35 AM
took apart the suspension sure enough the bearings are blown on the first shock, oh well worth a try
shady milkman
Apr 1, 2021 09:57 PM
Fanuvkorn
Sep 23, 2020 09:24 AM
Erwan88
Feb 20, 2012 05:15 PM
Spike555
Aug 28, 2010 05:15 PM
kaczman
Feb 4, 2007 04:22 AM
