lift kit
Old Mar 12, 2014 | 11:17 PM
velija's Avatar
Default lift kit
here is a link to what im looking at
why should i not do this
thanks for the advise in advance
Land Rover Discovery Series II 1999.5-2004 Suspension Lift Kits
Old Mar 13, 2014 | 07:57 AM
jeffh's Avatar
are you replacing your springs and shocks as well? If not and they are old/stock putting your truck up on spacers is not the best idea. If you go new springs and shocks you will be in effect raising your truck 1.5-2. inches due to the old stuff sagging. you ride will be better, and safer.
Old Mar 13, 2014 | 08:17 AM
dusty1's Avatar
you would be missing out on the ride quality, travel, rating of new springs.
Old Mar 13, 2014 | 09:49 AM
ZGPhoto's Avatar
$499 gets you new shocks AND springs, that will last you much longer than your current setup. If you lift a truck without putting longer shocks on you're going to destroy the shocks.
Old Mar 13, 2014 | 10:07 AM
Dave03S's Avatar
If you instal new shocks without new springs on these very heavy trucks you will prematurely wear out your new shocks.
Old Mar 13, 2014 | 10:24 AM
remac's Avatar
Spend the money and get OME. Mine has the 2" springs and shocks. Rides better than stock and just enough lift. One note is that 265 BFG tires do rub at full lock sometimes if the truck is not completely level.
Old Mar 13, 2014 | 06:12 PM
velija's Avatar
Ok ok I value all of your suggestion and therefore this idea is of the table
Now any suggestions what I should get that will lift me up a bit in the $500 range
Share a link if you can as well please
Once again thank you all
Old Mar 13, 2014 | 06:54 PM
jeffh's Avatar
here you go.
Lucky8llc.com - OME Products for Land Rovers
Old Mar 13, 2014 | 07:12 PM
ZGPhoto's Avatar
$788 is a bit higher than $500 though. Though OME's are great, they are expensive for not being worth $300 more than Terrafirmas.
COIL CONVERSION KIT HD TF +2" DSCO II , TF230 - Rovers North - Classic Land Rover Parts
or
Lucky8 Llc. - Take the road less traveled...
Old Mar 13, 2014 | 07:46 PM
velija's Avatar
Thanks fellows
Sorry but what's the difference between the medium and heavy load
Also the link rovers north it's $499 or am I seeing wrong
Thanks
