lift kit
here is a link to what im looking at
why should i not do this
thanks for the advise in advance
Land Rover Discovery Series II 1999.5-2004 Suspension Lift Kits
are you replacing your springs and shocks as well? If not and they are old/stock putting your truck up on spacers is not the best idea. If you go new springs and shocks you will be in effect raising your truck 1.5-2. inches due to the old stuff sagging. you ride will be better, and safer.
Ok ok I value all of your suggestion and therefore this idea is of the table
Now any suggestions what I should get that will lift me up a bit in the $500 range
Share a link if you can as well please
Once again thank you all
$788 is a bit higher than $500 though. Though OME's are great, they are expensive for not being worth $300 more than Terrafirmas.
COIL CONVERSION KIT HD TF +2" DSCO II , TF230 - Rovers North - Classic Land Rover Parts
or
Lucky8 Llc. - Take the road less traveled...
or
