Lift kit identification
Old Sep 9, 2019 | 11:54 AM
CameraDan's Avatar
Default Lift kit identification
I'm looking to identify the lift kit in my truck, which was installed by a previous owner. Didn't get any of the paperwork for that mod when I bought it, unfortunately. Now I need to do some suspension repairs, but I don't know what pieces I'm going to need.
Any thoughts on what parts I could look at to identify the kit?
What is the stock ride height front and rear, and what's the best way to measure this?
Old Sep 9, 2019 | 05:52 PM
Fastercat's Avatar
If you search this forum most guys measure the fender lip to the center of the wheel. I’m not sure what the measurements are. Your best off to dig around and see
Old Sep 10, 2019 | 05:16 AM
SundayFunday's Avatar
Post a photo.
what does suspension repairs mean ?
Old Sep 12, 2019 | 01:15 PM
CameraDan's Avatar
Took measurements from the wheel centres to the fender lip. Here's what I've got:
FL: 21.5"
FR: 20.5"
RR: 20.5"
RL: probably 20.5" (this is where the damage is)
Shocks are branded Terrafirma. Can't make out branding on any other parts.
Where else can I look for clues to figure out what lift this is?
Photos below:
Front suspension
Rear shock detail
Old Sep 12, 2019 | 01:34 PM
Dave03S's Avatar
Looks like you have TF aftermarket shock towers on the front too...
Old Sep 12, 2019 | 02:00 PM
CameraDan's Avatar
Yeah, this seems likely. They look a little newer than the rest of the suspension, as they are painted white.
Old Sep 12, 2019 | 06:15 PM
CameraDan's Avatar
I just found another thread that quotes 470mm (18.5") as the stock distance, wheel centres to fender. This leads me to believe that I've got a 2"Terrafirma kit.
Looking around at AB and Rovers North, it looks like a 2" medium duty spring and shock bundle is pretty common, and fits the bill for my truck. But that still leaves the shock towers as a mystery. What other parts might have been upgraded with a lift kit?
I know for sure that my radius arms are stock, at least. I've seen other kits that include things like a panhard bar, extended sway bar links, extended watts links, etc. Does anyone know the stock measurements of these pieces, to compare against my own?
Old Sep 12, 2019 | 06:33 PM
Fastercat's Avatar
I would guess you have a 2” medium duty terra Firma kit. I’m guessing this because of the terra Firma shocks and front shock towers
Old Sep 12, 2019 | 07:02 PM
ZGPhoto's Avatar
I don't know what kind of towers those are, but they're not Terrafirma
Old Sep 13, 2019 | 06:00 AM
I was under the impression that the higher you go, you educate & tackle additional suspension & driveline related parts as necessary & to discretion. I don’t think I’ve noticed a “kit” with anything more then springs/shocks.
Beauty of that 2” terra lift- is you really don’t need anything other then the time to install it to work well with everything else stock on these trucks.
miron
May 30, 2019 06:38 PM
scottz
Apr 24, 2019 09:31 PM
cobbcj7
Freelander
Oct 5, 2016 12:46 PM
trini defender
Defender
Nov 30, 2007 10:16 PM
Brad Luchtman
Nov 19, 2007 07:14 PM
