To lift or not to lift...that is the question
Old Sep 24, 2013 | 11:50 AM
dusty1's Avatar
with 18"
265 60 r18 no rub
265 65 r18 need to do a little air dam trimming
Old Sep 24, 2013 | 12:22 PM
antichrist's Avatar
Originally Posted by SuperSport
I wonder why that link doesn't cover 18" sizes? I don't remember what the max is at the moment, but I've seen people agree on a max 18" size on a couple threads.
Probably because when that list was done 18" were rare and decent off-road tires for 18" wheels were even more rare.
mattmo78's Avatar
It will be a lot more cost effective if you use a 2" lift kit instead of the 3". With a 3" kit, you will have to change out brake lines, drive shaft, and some other things under the truck. With a 2" kit, you can keep all of the stock components underneath.
I have a 2" TerraFirma kit in my garage waiting to be installed. I'm getting anxious to put it on.
Old Sep 24, 2013 | 12:25 PM
dusty1's Avatar
l8/justin said "no need for any other component change with the 3" tf pro sport lift"
originally, i just needed to free up abs lines
Old Sep 24, 2013 | 12:42 PM
antichrist's Avatar
I forgot to add, wheel diameter is pretty irrelevant. What matters is the OD and tread & section width of the tire.
Using the chart you can easily figure out what 17', 18', 20', etc tires will fit. Or even 15" if you want to go the other direction for wheel size.
Old Sep 24, 2013 | 12:57 PM
Ghaniba's Avatar
One thing to keep in mind is a lift is done to FIT tires. Tires are what will give you more height under the axles, which really is what will stop you. Breakover angle will be helped by lift, but the general rule is it's all for the tires to not rub offroad.
In the Jeep world, many people have moved to less lift and bigger tires by trimming, cutting etc - calling it an "LCG build" - where they now have a Lower Center of Gravity. This makes ALL the difference when going up a very steep incline.
The carport / garage is really key.
I have a 2000 Disco, w/ a sagging old OME 2" lift and 32s. It barely fits in my standard garage door. I'm concerned, when I go to a 3" and 33s that it really won't have a chance to fit... Time to build another garage w/ a 10' door... That said, there's another big issue that some don't think of - Parking garages. I don't often drive to them -- but there are times, and I know this truck will BARELY fit as it is. Literally waiting for the scrape on that test pipe that hangs on the entrances to show you the internal height!
If all of that doesn't matter, go with a 3" it'll sag eventually anyway and even a 2" w/ 32s will be more trouble to get in and out of. Anyone 5'8 and below will get to jump a bit.
Dave
Old Sep 24, 2013 | 04:26 PM
nychaze's Avatar
The higher you go the more the drive angles get thrown off. Stick with a 2", it will drive just like it does now.
Old Sep 24, 2013 | 06:25 PM
vibrolucky's Avatar
Great advice everyone! Thats why I love this forum...
I think I will stick with what I have for now and ease into it as a 'stock' LR. I may look into the 18" tires down the road, or perhaps to the 2" lift to keep things simple.
I only paid $4500 for the vehicle, and I'm quickly finding out that I could spend that amount and more on outfitting her for Off-road.
Being new to this scene, I think I will try it as-is for a few months.
Old Sep 24, 2013 | 06:54 PM
ZGPhoto's Avatar
There is no Terrafirma 3" kit... I'm going to kick Justin in the....
Old Sep 24, 2013 | 07:02 PM
jafir's Avatar
Hey, it's just marketing. The ome kits are actually measured in mm.
