Lift question
Old Oct 26, 2011 | 06:35 AM
01d2Jeff's Avatar
Default Lift question
Bear with me, because I'm a jeep guy....
When you lift a d2 2 inches, do you need a full kit, with panhard bars, radius arms, and new driveshafts, or can you get away with just springs and shocks as the suspension geometry isn't changing all that much?
Old Oct 26, 2011 | 07:11 AM
GreedyRover's Avatar
over 2" = radius arms/new shafts
Old Oct 26, 2011 | 07:20 AM
I'm running RTE HD 2" coils i also did the RTE adjustable pan hard rod and added the HP watts linkage in the rear. I never measured but I'm pretty sure i netted well over 3+ inches total.
Old Oct 26, 2011 | 07:27 AM
To set the records straight, you can go to 3"s without anything except brake hoses, yes there will be a little castor issue, but it usually doesn't both most people.
Old Oct 26, 2011 | 11:12 AM
01d2Jeff's Avatar
Thanks - what about pinion angles and driveline vibes?
Old Oct 26, 2011 | 09:14 PM
sloppyjoe's Avatar
none unless you go taller
Old Oct 27, 2011 | 10:08 AM
Jeff, if you have any questions, and there can be a lot based on the number of different Rover lifts available, send me your number and I'll be glad to walk you thru what to look for.
Old Oct 27, 2011 | 11:44 AM
01d2Jeff's Avatar
Thanks, Mike. I certainly appreciate it. I will definitely do so when I'm in the market - which will probably be around january or so - I just like to get all my questions answered before hand so I'm good & prepared. I hate getting 3/4 of the way through something and then realizing I don't have everything I need.
vibrolucky
Sep 25, 2013 10:28 AM
Emperor_MA
Jun 15, 2011 11:21 AM
calebbo
Feb 10, 2011 04:58 PM
Mr. Krisztian
Aug 16, 2007 11:36 PM
Bigmonty
Aug 8, 2007 07:13 AM
