Lifter/Valve Noise DISCO MIKE?
Old Dec 30, 2007 | 08:48 AM
howellja's Avatar
Default Lifter/Valve Noise DISCO MIKE?
"I was going to add that if yours is an 03, you could have big problems lurking."
I dont know if im going to be able to sleep! Luckily I bought an extended warranty if she doesblow!I have a 2003 that has just started to develop some lifter noise/valve tapon the passenger side. The last time I changed the oil it was about a half court low over 3000miles but couldnt find a leak. What do you guys advise? I was going to do an ATF engine flush and have the oil pressure checked in the next couple of weeks. Should i have the pressurechecked first thendo the clean out?Should I be ordering up an oil pan gasket for this piggy just in case I need to drop the pan and clean out pickup tube? Truck has been always dealer serviced and developed the noise recently, no oil loss on this oil change yet, Im running 5w30 mobile 1. Disco Mike?
Old Dec 30, 2007 | 11:17 AM
Default RE: Lifter/Valve Noise DISCO MIKE?
Don't do anything as far as a flush, call your dealer and get it in quickly, you may have one of the03 oil pumps failing.
Old Dec 30, 2007 | 12:49 PM
okdiscoguy's Avatar
Didn't mean to scare you, just make you aware that the 03's have lost a lot of oil pumps, and it can be corrected if you get it in to the shop soon.
Old Jan 1, 2008 | 06:57 AM
howellja's Avatar
No sometimes itsok to be scared,thanks for the response guys! I hadnt read that about the 2003! The truck has always been dealer serviced with its last check-up about 4,000 miles ago. It is going in next week for my valve noise and leaky rear sunroof again.
ScottDresler.
Aug 22, 2010 03:34 PM
newdr
Nov 24, 2009 05:10 PM
SpdDemon426
Nov 9, 2009 05:01 PM
Evergreen Bob
May 28, 2009 08:23 AM
gsxrgessler
Nov 3, 2007 04:03 PM
