Light bulb question
RE: Light bulb question
Simply remove the two screws located at the top of the light housing. Then gently pull on the outboard most portion of the housing. There are two stem like male connectors that will release from a female receiver giving you access to the back.
I’ve changed the bulbs twice and have never been able to get the unit off completely. That’s ok. You can reach in behind the housing and access the plug and bulb there.
10 Minute project.
MWMG
10 Minute project.
MWMG
I have a 2003 disco and just replaced the headlights. Yes it is a slight undertaking (removing the grill and in my case working around the winch bumper) the but can be accomplished in about 10-15 minutes. I have a question though...how do you go about leveling them? Any tips would be appreciated.
Thanks,
Brian
Thanks,
Brian
