Light bulb question
Old Nov 18, 2007 | 08:03 PM
greenhulk1980's Avatar
Default Light bulb question
Hola, I have a 2003 discovery that needs the light bulbs changed. The manual shows the front grille having to come off to accomplish this. Can anyone give me some guidance? Thanks.
Old Nov 19, 2007 | 11:42 AM
Default RE: Light bulb question
Does anyone know how to change a light bulb in a 2003 disco? just tried what the manual says but that involves taking off nearly the entire front end.
Old Nov 19, 2007 | 12:02 PM
DeepBlueWater's Avatar
Simply remove the two screws located at the top of the light housing. Then gently pull on the outboard most portion of the housing. There are two stem like male connectors that will release from a female receiver giving you access to the back.
I’ve changed the bulbs twice and have never been able to get the unit off completely. That’s ok. You can reach in behind the housing and access the plug and bulb there.
10 Minute project.
MWMG
Old Nov 26, 2007 | 09:59 PM
Wheats's Avatar
3rd Gear
I have a 2003 disco and just replaced the headlights. Yes it is a slight undertaking (removing the grill and in my case working around the winch bumper) the but can be accomplished in about 10-15 minutes. I have a question though...how do you go about leveling them? Any tips would be appreciated.
Thanks,
Brian
TRIARII
Dec 9, 2013 06:24 PM
Classklown90
Aug 21, 2010 07:24 PM
mcbenavidez
Nov 24, 2007 05:47 PM
burtondr
Oct 20, 2007 05:19 PM
AzCamel
Jun 14, 2005 08:39 PM
